1.目的: 使各种标准目视化,能显示异常情况及实际情况与目标之间的差距,并能方便指导与解释,促进信息交流。 PurposeLet every standard is visual, and display the gap between abnormity situation,actual situation and goal,and can conduct and explain expediently,promote communication. 2.适用范围: 上海通用东岳汽车有限公司 Scope of Application Shanghai GM DongYue Motors Company Limited 3.规定: Provision 3.1东岳区域标识颜色使用规定 DongYue area mark color using provision 3.1.1颜色分类: Color system ——绿色:安全标识,表示此区域可以进入、穿越。主要用于安全通道,安全通道的宽度范围为60-80CM。 ——Green:Safety Mark,denote this area can enter and pass through. Mainly use in safety chunnel. The width of safety is 60-80CM. ——黄色:警告标识,表示需要注意的部位。黄色区域可以穿越,但在经过此区域时必须小心,提高注意 力,也用于生产线上的70%线等。 ——Yellow:Warning Mark, denote this part should be attention. Yellow area can pass through, but should be very carefully.Yellow also use in production line 70% line. |
