[资料] 伟创力smedFBP-LSS-F135-A_SMED
spaceman 发表于 2012-1-26 10:01:56 | 显示全部楼层 |阅读模式 打印 上一主题 下一主题
TIP: Ask yourself:
“How tight is tight
enough?”
“Do you need that
length of pipe welded to
your spanner?”
“Do you need that final,
teeth clenching
tightening?”
Problem:
Internal setups:
• Barrel Cleaning
• Mold unloading
• Mold Loading
• M/c. parameter setting
• Purging the Barrel
External setups:
- Unloading resin from hopper
- Raw material drying
- Drying Hopper cleaning
- Place mold (to be loaded) & tools near the M/c
Internal steps are those activities that must be performed when the
equipment is turned off / idle
External steps are those activities that can be performed in
anticipation of a changeover or while the current job is running
本帖子中包含更多资源
您需要 登录 才可以下载或查看,没有账号?立即注册
x
精彩评论9
gtsnake 发表于 2012-1-26 16:00:55 | 显示全部楼层
非常棒的快速换模材料,楼主辛苦了.
期望伟创力的单元生产、价值流等全套材料
alexbu 发表于 2012-1-27 11:13:43 | 显示全部楼层
多谢王老大分享伟创力的资料
zjmichan 发表于 2012-1-30 15:45:16 | 显示全部楼层
非常棒的材料,楼主辛苦了
crd 发表于 2012-5-14 12:11:37 | 显示全部楼层
非常棒的材料,谢谢分享!
cyw4671 发表于 2012-5-15 20:40:00 | 显示全部楼层
谢谢分享,学习了
hedydbs 发表于 2012-5-15 21:54:37 | 显示全部楼层
分享成功,共享成长!
ヤo.0n!y 发表于 2012-5-15 22:01:33 | 显示全部楼层
王总,你的英格利希不错
hhk715 发表于 2013-8-28 20:58:21 | 显示全部楼层
非常感谢分享。
alvin0791 发表于 2023-7-16 16:11:00 | 显示全部楼层
谢谢楼主分享
